TPS25921A: adding two in parallel to achieve higher current.
Part Number: TPS25921A
Can I add two TPS25821A in parallel to achieve more current? If yes, can both chips share the same passives?
I am not sure about current limit resistor connected to ILIM pin as there will be a current source from each part going down this common resistor.
