Other Parts Discussed in Thread: EV2400
I have the Fuse drive section of the BQ4050 configured as in the schematic below. I verify that the FUSE signal is low. Then, I attempt to solder the positive terminal of a battery to my PCB. After the soldering process, the FUSE pin is asserted, turning FET Q7 on. As a result, when the top most battery is soldered to the PCB the enabled FET causes a path to ground blowing the FUSE. At the moment, I believe this to be the result of the solder tip being energized and causing a voltage differential on my PCB. Have you ever encountered something like this before? If so, how do I get around it? Let me know if you require any additional information.
Thank you,
