The datasheet walks through how to create your own little LDO for the REG IN pin (which can take between 2.7-4.2V)...
If I have a battery powered system (5S2P, 18.5V nominal) and a 3.3V Buck regulator already in the system, is there any issue with simply using the 3.3V Buck?
I feel this would be more power efficient than burning power across a zener diode and resistor as the datasheet and EVM show.
