Other Parts Discussed in Thread: BQ2057, CSD25404Q3
We are Using BQ2057 battery charger IC in our product to charge the 8.4V battery through 9V-1A adapter. As per the datasheet to enable/disable the charging process, we used AO4409 FET in between adapter and battery.
Whenever the beginning of battery charging (Charging Current 0.5A) this FET and BQ2057 getting very hot, because of across FET dropout voltage is more.
For this issues we are facing more failure case of broads.
