Part Number: TPS61169
Below red circle voltage maximum rating, could I know how much time could be accepted by 7V voltage? What is max. LED current per channel of tps61169 ? Thank you.
BR
Patrick
BR
Patrick
Hi, typically user can operate part safely within abx value. however, due to ripple, mismatch, the voltage output could exceed abx value during operation, that's why we have recommended voltage range to leave some margin. anyway, 7V should be good as long as it not go beyond it. in terms of the current, it's depends on the FET current limit (1.2A minmum) and LED itself. hope this can help..
