Dears:
My customer is using TPS73733(fixed output), when EN=0, it can't disable output, finally I found that the phenomenon disappears when cut the connection between TPS73733 and load, the load includes 2pcs SX1276, it is obvious that there is no problem with tps73733, I doubt there are too many decoupling capacitors in the load, but I am not sure about it, could you give me your suggestion? thanks
