hi to all and thank you for taking the time to assist us in our design.
We want to reduce the noise of this convertor to very low levels. After reading your own papers we decided to place some RC snubbers.
On positive side , we placed a RC snubber across INP and OUTP . We tested . Some oscillations and noise are reduced. However the main SW mosfet is between INP and GND. Can we place a RC snubber between INP and GDN ? (220pf/10R)
Second on the negative side (on the block diagram from the datasheet) we only see one SW mosfet . So we assume we can place a RC snubber between INN and OUTN . However the second mosfet is not present. Can we also place a RC snubber between INN and GDN ?
waiting for your reply.
thank you in advance.
Andre
