Hi Team
I have one question for Charge Enable / Disable ISET control with STAT signal .
We did test Charge Disable / Enable by ISET change Voltage under 40mV( Disable) or about 120mV (Enable ).
I think charge Enable / Disable control is Ok, But STAT pin LED has little time flashing.
This is BQ24171 data sheet Figure 2 Charge Enable by ISET
[ Question ]
a) STAT signal has little time Flashing with LED.
Is this Device Spec ??
b) Customer want to Charge Enable / Disable control without STAT LED Flashing .
Can possible Charge control with out STAT LED Flashing ??
or dose we have other way for Charge Control ?
c) Please tell us about this STAT Flashing Reason by ISET Charge Control ?
For instance
Starr Charge sequence or TS temp check or Deglitch Time ???
Thanks and Regard
Jasper ( Sugimoto )
