Part Number: TPS659037
Other Parts Discussed in Thread: AM5726, TPS65917-Q1
To whom it may concern,
I have question about power sequence of TPS6590378.
(Customer Conditions)
1, Customer system is suddenly powered.
Also, when the system is turned off, the power supply is instantly interrupted.
2, Customer would like to design a system that automatically starts up and shuts down, when there is occurred above conditions.
(Question)
- For power up;
When POWERHOLD pin is connected to LDOVRTC(pull-up), is "ON Request" executed successfully?
- For power down;
If POWERHOLD pin is pulled up, is the shutdown executed normally?
Could you please confirm the attached file about the detail?
After you check the attached file, could you please point out if there is a problem part about the attached file?
Gk110
