Other Parts Discussed in Thread: LM5069
Considering information given sections 8.1.5 and 8.2.1.2.3 of LM5060 datasheet, an overcurrent is detected if the difference between SENSE and OUT pins exceeds the VDSTH during configurable VDS fault delay. In this case the external MOSFET is turned off and its gate is discharged at a 80 mA rate.
As VDSTH threshold is related to the overcurrent limit. When an overcurrent is detected, does LM5060 limits the output current to the overcurrent limit? I mean, does LM5060 limits the output current during VDS fault delay before switching off the MOSFET?
Thank you in advance.
