Other Parts Discussed in Thread: GPCCHEM
We did a learning cycle, but Qmax cell 0 is not updated.
What could be the possible reasons?
Logs are available under this link
Hi Valery,
What is your update status at? Did you program the correct chem id for your cells? Did you follow the learning cylce procedure as per this documentation?
7446.LearningCycleOverview_.pdf
thanks
Onyx
1. "Update Status" is "04"
2. chem id wasn't changed by us, so it's default.We couldn't find the appropriate manufacturer
from the list. We have a Li-Pol battery.
3. Can you check our log file attached in the initial message? Are there any anomalies there
or a clue why Qmax cell 0 is not updated?
The problem is obvious. You used the default chem id which is likely not a match for your cell hence update status staying as 04. You need to correctly identify your chem id and redo your learning cycle following the pdf i sent you.
thanks
Onyx
