Hi team
I see below at datasheet.
If the value of Radj equals 680K, Current Limit has about 500A.
However, current consumption is only 1A.
Is that a problem?
Taemin
Hi team
Is that a problem?
Taemin
Hi Katelyn
Thank you for your help.
I can not find a statement to use 3.1K or less on the datasheet.
Can you tell where the phrase is located?
If you are talking about 2.1K, there is mention but you can not find anything to use less than that.
Taemin
Hi Taemin,
Please disregard my previous statement. I looked into this again, and the important limitation is on Page 4 of the EVM document. This specifies the limitation of the voltage across R5 as 50mV to 100mV. The true limitations of Rsen is Rsen<100mV/(Isen). This information is on Page 4 of the EVM document:
Katelyn Wiggenhorn
