Looks like that the TI SW works fine when I use Tiger board and our SW, I can write the registers properly using I2C but can’t read the registers back.
If you know someone from TI, could you ask them “what is the format to read the R/W registers using I2C since its document doesn’t have the format”?
A I2C command or a diagram example using I2C to read the registers will be helpful.
