Part Number: TPS62180
I have a configuration which the tps62180 output is wired-or with LDO output. At anytime, only one will be enabled. If LDO is enabled, would there be a reverse flow on tps62180? Would I see voltage at Vin? Will it damage the device?
Thanks.
- YY
