Hello Sir/Madam,
I have an issue with getting an output voltage of the fuel gauge.If I short once TP1 and TP2 as per attached schematic then only mosfet is initiate and fuel gauge give its output but if I o7446.SCHEMATIC1 _ PAGE1.pdfnce can't short this two test pad fuel gauge is not working.
So I want to know what happens in mosfet characteristic and What is the permanent solution for this thing if I don't want short once this two test pad according to attache schematic?
Kindly tell as if you require more information for the same.
Thanks & Regards,
Denish Limbachiya.
Embedded Hardware Engineer.
