Other Parts Discussed in Thread: LM317, TPS7A33
In the uA7805 datasheet it says that with a floating negative voltage you can use the 7805 as a negative regulator by connecting its output to ground and using the ground side of the 7805 as the output. Would the same idea work for the LM317 LM350 type voltage regulator to be adjustable?
