BQ27742-G1: How to write memory
Part Number: BQ27742-G1
Hi, I'm in trouble because I want to make a custom procedure to write the .srec file or the other generated by bqstudio into my device memory. I have a procedure to write the .dfi file for another device, the bq27410, it's the same? Bacause I've found that important data to use in .srec generated from bqstudio are from 0x4000 to 0x43ff, so I think to use this data and program it on my bq27742. Is this correct? Because there is no documentation on how to write on memory. If you have any hidden documentation could you share with me?
Best regards
Enrico
