Hi
Does TI has Buck converters that support Open voltage regulator standard for for Nvidia TX1 processor
in Type 2 BT and DT type modules for CPU core voltage generation
Hi
AGXIN said:Part Number: TPS51313
Hi
Does TI has Buck PWM/PFM Controllers sporting that support Open voltage regulator standard for for Nvidia TX1 processor
in Type 2 (single or Dual phase ) BT and DT type modules for CPU core voltage generation
Hi AGXIN,
As I know, there should be no more parts specially designed for Nvidia processor.
Could you please tell the detailed requirment, what's the special spec. for TX1? let me check whether others part can meet this.
Yuchang
Hi
After studied the document, looks TPS51313 just meet type 0 spec.
For typy 2, there is no proper part in my BU, so I suggest you to submit a new question, change the title, maybe named " please recommend 2-phase controller for Nvidia ....", other BU's guys may help to recommend parts for you.
Also you can check below websit to see whether there is proper part for your application.
