Other Parts Discussed in Thread: BQSTUDIO, GPCCHEM, BQ27426
For calibrating host side fuel gauges, is there a software interface to use for the calibration or the calibration sequence should be included in the host code? I've found the below documents but I'm still a little confused on the process. The documents also mentioned needing an EVM to generate the DFI file. Does TI has dedicated modules for this?
Is the calibration process the same for all system side gauges, or is it device specific?
Thank you!
Ryan B.
