BQ27742-G1: feul gauge battery learning cycle process
Part Number: BQ27742-G1
Other Parts Discussed in Thread: BQ27742EVM, BQSTUDIO
Hi there,
We plan to use bqstudio, bq27742evm and bq25898devm to do the learning cycle. I have read the Learning cycle procedure and the Achieving the successful learning cycle documents, and I think I got the procedure. I have some questions to ask before starting the cycle:
  1. I know the parameter chem ID needs to be updated to match the battery under test before the cycle started. What else have to be updated in order to achieve the successful learning cycle before start the cycle?
  2. How to send IT enable command or Reset command in bqStudio 1.3.54.1? Do I just click the IT_ENABLE or RESET button in the Commands panel on the right side of the screen window?
  3. The procedure asks to log Data memory and Data flash during the cycle for analyse. I think I know how to set log for data memory (go Window>Preferences>data memory, enter the interval and file name), but don't know where to set the data flash log. Can you point me out where to go for the flash log?
Thanks!
Mike
