We launched a product two years ago that uses BQ34Z100-G1 mainly to monitor our internal battery level (1S2P 1200mAh, Lithium-ion). The gauge was calibrated and a golden image was generated by TI FAE team in Taiwan.
We recently observed an uptake from customers reprorting that battery level isn't accurate.
From our investigation, the values of battery gauge registers:
RemainingCapacity() - RM - 0x04/0x05
FullChargeCapacity() - FCC - 0x06/0x07
TrueRC() - TRC - 0x68/0x69
TrueFCC() - TFCC - 0x6A/0x6B
are often do not behave adequately during the process of charging and discharging (and especially repeated partial charging or discharging).
-- In the process of repeated charging/discharging cycles (possibly partial) FullChargeCapacity() sometimes happen to get weird values like 600mAh or even 100-300mAh. FCC value may recover to expected value sometime after a few cycles of discharging/charging . We observed values of FullChargeCapacity() as small as 74mAh and on one device even 0mAh (even though battery doesn't seem to be at fault).
So in short: FullChargeCapacity() sometimes happen to be random and unpredictable with no clear explanation how it happened.
Please let me know if you have any idea what could lead to this problem and if you have any recommendation for actions we could take. Thank you!
I've exported Data flash file (.csv format) in included in here. I added a column so you can compare the values between a new unit and an old unit.
* Texas Instruments Data Flash File | |||||
* | Values of a new unit | Values of an old unit | |||
* Field Order: Class name | Subclass name | Parameter name | Parameter Value | Parameter Value | Display Units |
Configuration | Safety | OT Chg | 55 | 55 | 1degC |
Configuration | Safety | OT Chg Time | 2 | 2 | Seconds |
Configuration | Safety | OT Chg Recovery | 50 | 50 | 1degC |
Configuration | Safety | OT Dsg | 60 | 60 | 1degC |
Configuration | Safety | OT Dsg Time | 2 | 2 | Seconds |
Configuration | Safety | OT Dsg Recovery | 55 | 55 | 1degC |
Configuration | Charge Inhibit Cfg | Chg Inhibit Temp Low | 0 | 0 | 1degC |
Configuration | Charge Inhibit Cfg | Chg Inhibit Temp High | 45 | 45 | 1degC |
Configuration | Charge Inhibit Cfg | Temp Hys | 5 | 5 | 1degC |
Configuration | Charge | Suspend Low Temp | -5 | -5 | 1degC |
Configuration | Charge | Suspend High Temp | 55 | 55 | 1degC |
Configuration | Charge | Pb EFF Efficiency | 100 | 100 | % |
Configuration | Charge | Pb Temp Comp | 24.96 | 24.96 | % |
Configuration | Charge | Pb Drop Off Percent | 96 | 96 | % |
Configuration | Charge | Pb Reduction Rate | 10 | 10 | % |
Configuration | Charge Termination | Taper Current | 296 | 296 | mAmp |
Configuration | Charge Termination | Min Taper Capacity | 240 | 240 | mAmpHr |
Configuration | Charge Termination | Cell Taper Voltage | 100 | 100 | mVolt |
Configuration | Charge Termination | Current Taper Window | 40 | 40 | Seconds |
Configuration | Charge Termination | TCA Set % | 99 | 99 | Percent |
Configuration | Charge Termination | TCA Clear % | 95 | 95 | Percent |
Configuration | Charge Termination | FC Set % | -1 | -1 | Percent |
Configuration | Charge Termination | FC Clear % | 98 | 98 | Percent |
Configuration | Charge Termination | DODatEOC Delta T | 10 | 10 | 1degC |
Configuration | Charge Termination | NiMH Delta Temp | 3 | 3 | 1degC |
Configuration | Charge Termination | NiMH Delta Temp Time | 180 | 180 | Seconds |
Configuration | Charge Termination | NiMH Hold Off Time | 100 | 100 | Seconds |
Configuration | Charge Termination | NiMH Hold Off Current | 240 | 240 | mAmp |
Configuration | Charge Termination | NiMH Hold Off Temp | 25 | 25 | 1degC |
Configuration | Charge Termination | NiMH Cell Negative Delta Volt | 17 | 17 | mVolt |
Configuration | Charge Termination | NiMH Cell Negative Delta Time | 16 | 16 | Seconds |
Configuration | Charge Termination | NiMH Cell Neg Delta Qual Volt | 4200 | 4200 | mVolt |
Configuration | Data | Manufacture Date | 1/1/1980 | 1/1/1980 | Day + Mo*32 + (Yr -1980)*256 |
Configuration | Data | Serial Number | 1 | 1 | hex |
Configuration | Data | Cycle Count | 0 | 5 | Count |
Configuration | Data | CC Threshold | 960 | 960 | mAmpHr |
Configuration | Data | Max Error Limit | 100 | 100 | % |
Configuration | Data | Design Capacity | 1160 | 1160 | MilliAmpHour |
Configuration | Data | Design Energy | 4440 | 4440 | MilliWattHour |
Configuration | Data | SOH Load I | -400 | -400 | MilliAmp |
Configuration | Data | Cell Charge Voltage T1-T2 | 4200 | 4200 | mV |
Configuration | Data | Cell Charge Voltage T2-T3 | 4200 | 4200 | mV |
Configuration | Data | Cell Charge Voltage T3-T4 | 4200 | 4200 | mV |
Configuration | Data | Charge Current T1-T2 | 10 | 10 | Percent |
Configuration | Data | Charge Current T2-T3 | 50 | 50 | Percent |
Configuration | Data | Charge Current T3-T4 | 30 | 30 | Percent |
Configuration | Data | JEITA T1 | 0 | 0 | degC |
Configuration | Data | JEITA T2 | 10 | 10 | degC |
Configuration | Data | JEITA T3 | 45 | 45 | degC |
Configuration | Data | JEITA T4 | 55 | 55 | degC |
Configuration | Data | Design Energy Scale | 1 | 1 | Number |
Configuration | Data | Device Name | bq34z100-G1 | bq34z100-G1 | - |
Configuration | Data | Manufacturer Name | Texas Inst. | Texas Inst. | - |
Configuration | Data | Device Chemistry | LION | LION | - |
Configuration | Discharge | SOC1 Set Threshold | 174 | 174 | mAh |
Configuration | Discharge | SOC1 Clear Threshold | 203 | 203 | mAh |
Configuration | Discharge | SOCF Set Threshold | 87 | 87 | mAh |
Configuration | Discharge | SOCF Clear Threshold | 116 | 116 | mAh |
Configuration | Discharge | Cell BL Set Volt Threshold | 3000 | 3000 | mVolt |
Configuration | Discharge | Cell BL Set Volt Time | 2 | 2 | Seconds |
Configuration | Discharge | Cell BL Clear Volt Threshold | 3200 | 3200 | mVolt |
Configuration | Discharge | Cell BH Set Volt Threshold | 4200 | 4200 | mVolt |
Configuration | Discharge | Cell BH Volt Time | 2 | 2 | Seconds |
Configuration | Discharge | Cell BH Clear Volt Threshold | 4200 | 4200 | mVolt |
Configuration | Discharge | Cycle Delta | 0.05 | 0.05 | % |
Configuration | Manufacturer Data | Pack Lot Code | 0 | 0 | hex |
Configuration | Manufacturer Data | PCB Lot Code | 0 | 0 | hex |
Configuration | Manufacturer Data | Firmware Version | 0 | 0 | hex |
Configuration | Manufacturer Data | Hardware Revision | 0 | 0 | hex |
Configuration | Manufacturer Data | Cell Revision | 0 | 0 | hex |
Configuration | Manufacturer Data | DF Config Version | 0 | 0 | hex |
Configuration | Lifetime Data | Lifetime Max Temp | 30 | 79 | 1degC |
Configuration | Lifetime Data | Lifetime Min Temp | 20 | -13.9 | 1degC |
Configuration | Lifetime Data | Lifetime Max Chg Current | 1291 | 1865 | mAmp |
Configuration | Lifetime Data | Lifetime Max Dsg Current | -1884 | -1884 | mA |
Configuration | Lifetime Data | Lifetime Max Pack Voltage | 210 | 210 | 20mV |
Configuration | Lifetime Data | Lifetime Min Pack Voltage | 151 | 149 | 20mV |
Configuration | Lifetime Temp Samples | LT Flash Cnt | 12 | 66 | Count |
Configuration | Registers | Pack Configuration | 1.00E+01 | 1.00E+01 | flags |
Configuration | Registers | Pack Configuration B | a1 | a1 | flags |
Configuration | Registers | Pack Configuration C | 33 | 33 | flags |
Configuration | Registers | LED_Comm Configuration | 0a | 0a | flags |
Configuration | Registers | Alert Configuration | 0 | 0 | flags |
Configuration | Registers | Number of series cell | 1 | 1 | num |
Configuration | Lifetime Resolution | LT Temp Res | 1 | 1 | 1degC |
Configuration | Lifetime Resolution | LT Cur Res | 100 | 100 | mA |
Configuration | Lifetime Resolution | LT V Res | 1 | 1 | 20mV |
Configuration | Lifetime Resolution | LT Update Time | 60 | 60 | Seconds |
Configuration | LED Display | LED Hold Time | 4 | 4 | Num |
Configuration | Power | Flash Update OK Cell Volt | 2800 | 2800 | mVolt |
Configuration | Power | Sleep Current | 10 | 10 | mAmp |
Configuration | Power | FS Wait | 10 | 10 | Seconds |
System Data | Manufacturer Info | Block A 0 | 20 | 20 | hex |
System Data | Manufacturer Info | Block A 1 | 16 | 16 | hex |
System Data | Manufacturer Info | Block A 2 | 7 | 7 | hex |
System Data | Manufacturer Info | Block A 3 | 26 | 26 | hex |
System Data | Manufacturer Info | Block A 4 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 5 | 1 | 1 | hex |
System Data | Manufacturer Info | Block A 6 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 7 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 8 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 9 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 10 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 11 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 12 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 13 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 14 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 15 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 16 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 17 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 18 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 19 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 20 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 21 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 22 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 23 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 24 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 25 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 26 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 27 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 28 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 29 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 30 | 0 | 0 | hex |
System Data | Manufacturer Info | Block A 31 | 0 | 0 | hex |
Gas Gauging | IT Cfg | Load Select | 2 | 2 | Number |
Gas Gauging | IT Cfg | Load Mode | 1 | 1 | Number |
Gas Gauging | IT Cfg | Res Current | 10 | 10 | mAmp |
Gas Gauging | IT Cfg | Max Res Factor | 50 | 50 | num |
Gas Gauging | IT Cfg | Min Res Factor | 1 | 1 | num |
Gas Gauging | IT Cfg | Ra Filter | 500 | 500 | num |
Gas Gauging | IT Cfg | Min PassedChg NiMH-LA 1st Qmax | 50 | 50 | % |
Gas Gauging | IT Cfg | Maximum Qmax Change | 100 | 100 | % |
Gas Gauging | IT Cfg | Cell Terminate Voltage | 3200 | 3200 | mVolt |
Gas Gauging | IT Cfg | Cell Term V Delta | 200 | 200 | mVolt |
Gas Gauging | IT Cfg | ResRelax Time | 500 | 500 | Seconds |
Gas Gauging | IT Cfg | User Rate-mA | 0 | 0 | MilliAmp |
Gas Gauging | IT Cfg | User Rate-Pwr | 0 | 0 | mW/cW |
Gas Gauging | IT Cfg | Reserve Cap-mAh | 0 | 0 | MilliAmpHour |
Gas Gauging | IT Cfg | Reserve Energy | 0 | 0 | mWh/cWh |
Gas Gauging | IT Cfg | Max Scale Back Grid | 4 | 4 | num |
Gas Gauging | IT Cfg | Cell Min DeltaV | 0 | 0 | mVolt |
Gas Gauging | IT Cfg | Ra Max Delta | 15 | 15 | % |
Gas Gauging | IT Cfg | Design Resistance | 173 | 173 | mOhms |
Gas Gauging | IT Cfg | Reference Grid | 4 | 4 | - |
Gas Gauging | IT Cfg | Qmax Max Delta % | 10 | 10 | mAmpHour |
Gas Gauging | IT Cfg | Max Res Scale | 32000 | 32000 | Num |
Gas Gauging | IT Cfg | Min Res Scale | 1 | 1 | Num |
Gas Gauging | IT Cfg | Fast Scale Start SOC | 10 | 10 | % |
Gas Gauging | IT Cfg | Charge Hys V Shift | 40 | 40 | mVolt |
Gas Gauging | IT Cfg | Smooth Relax Time | 1000 | 1000 | s |
Gas Gauging | Current Thresholds | Dsg Current Threshold | 60 | 60 | mAmp |
Gas Gauging | Current Thresholds | Chg Current Threshold | 75 | 75 | mAmp |
Gas Gauging | Current Thresholds | Quit Current | 40 | 40 | mAmp |
Gas Gauging | Current Thresholds | Dsg Relax Time | 60 | 60 | Seconds |
Gas Gauging | Current Thresholds | Chg Relax Time | 60 | 60 | Seconds |
Gas Gauging | Current Thresholds | Cell Max IR Correct | 400 | 400 | mV |
Gas Gauging | State | Qmax Cell 0 | 1171 | 1174 | mAmpHr |
Gas Gauging | State | Cycle Count | 0 | 0 | num |
Gas Gauging | State | Update Status | 6 | 6 | num |
Gas Gauging | State | Cell V at Chg Term | 4187 | 4158 | mVolt |
Gas Gauging | State | Avg I Last Run | -239 | -779 | mAmp |
Gas Gauging | State | Avg P Last Run | -906 | -2944 | MilliWattHour |
Gas Gauging | State | Cell Delta Voltage | 1 | 8 | mVolt |
Gas Gauging | State | T Rise | 20 | 20 | Num |
Gas Gauging | State | T Time Constant | 1000 | 1000 | Num |
Ra Tables | Ra0 Table | Ra Flag | 55 | 0 | Hex |
Ra Tables | Ra0 Table | Ra 0 | 56 | 46 | Num |
Ra Tables | Ra0 Table | Ra 1 | 56 | 46 | Num |
Ra Tables | Ra0 Table | Ra 2 | 176 | 153 | Num |
Ra Tables | Ra0 Table | Ra 3 | 227 | 283 | Num |
Ra Tables | Ra0 Table | Ra 4 | 173 | 429 | Num |
Ra Tables | Ra0 Table | Ra 5 | 181 | 552 | Num |
Ra Tables | Ra0 Table | Ra 6 | 235 | 840 | Num |
Ra Tables | Ra0 Table | Ra 7 | 218 | 772 | Num |
Ra Tables | Ra0 Table | Ra 8 | 218 | 772 | Num |
Ra Tables | Ra0 Table | Ra 9 | 217 | 772 | Num |
Ra Tables | Ra0 Table | Ra 10 | 193 | 714 | Num |
Ra Tables | Ra0 Table | Ra 11 | 233 | 840 | Num |
Ra Tables | Ra0 Table | Ra 12 | 285 | 1041 | Num |
Ra Tables | Ra0 Table | Ra 13 | 349 | 1242 | Num |
Ra Tables | Ra0 Table | Ra 14 | 3438 | 12400 | Num |
Ra Tables | Ra0x Table | Ra Flag | 0 | 55 | Hex |
Ra Tables | Ra0x Table | Ra 0 | 56 | 46 | Num |
Ra Tables | Ra0x Table | Ra 1 | 56 | 46 | Num |
Ra Tables | Ra0x Table | Ra 2 | 176 | 153 | Num |
Ra Tables | Ra0x Table | Ra 3 | 227 | 309 | Num |
Ra Tables | Ra0x Table | Ra 4 | 173 | 468 | Num |
Ra Tables | Ra0x Table | Ra 5 | 181 | 603 | Num |
Ra Tables | Ra0x Table | Ra 6 | 235 | 917 | Num |
Ra Tables | Ra0x Table | Ra 7 | 218 | 843 | Num |
Ra Tables | Ra0x Table | Ra 8 | 218 | 843 | Num |
Ra Tables | Ra0x Table | Ra 9 | 217 | 843 | Num |
Ra Tables | Ra0x Table | Ra 10 | 193 | 780 | Num |
Ra Tables | Ra0x Table | Ra 11 | 233 | 917 | Num |
Ra Tables | Ra0x Table | Ra 12 | 285 | 1137 | Num |
Ra Tables | Ra0x Table | Ra 13 | 364 | 1356 | Num |
Ra Tables | Ra0x Table | Ra 14 | 3586 | 13539 | Num |
Calibration | Data | CC Gain | 10.748 | 10.748 | mohm |
Calibration | Data | CC Delta | 10.73 | 10.73 | mohm |
Calibration | Data | CC Offset | -1273 | -1274 | num |
Calibration | Data | Board Offset | 14 | 14 | num |
Calibration | Data | Int Temp Offset | 0 | 0 | degC |
Calibration | Data | Ext Temp Offset | 0 | 0 | degC |
Calibration | Data | Voltage Divider | 5004 | 5004 | mVolt |
Calibration | Current | Deadband | 5 | 5 | mAmp |
Security | Codes | Sealed to Unsealed | 36720414 | 36720414 | hex |
Security | Codes | Unsealed to Full | ffffffff | ffffffff | hex |
Security | Codes | Authen Key3 | 1234567 | 1234567 | hex |
Security | Codes | Authen Key2 | 89abcdef | 89abcdef | hex |
Security | Codes | Authen Key1 | fedcba98 | fedcba98 | hex |
Security | Codes | Authen Key0 | 76543210 | 76543210 | hex |
