Output Impedance characteristics
Hi, team.
A output impedance vs frequency is indicated on several LDO, but how should this parameter be used?
Is it related in stability or noise performance?
  • Hi Hirotsugu,
    an example: Assume the output impedance is 100R at 1kHz and you have a load which is drawing an AC load current of 1mAp at 1kHz out of the output, than the output voltage of regulator is no longer constant but shows an AC ripple of 0.1Vp!
    Kai
