I'm trying to generate a golden file using the bq EVM, and whenever I try to write the settings from one of my own .EZY files to the device, I get the following:
Run-time error '6':
Overflow
Writing the .EZY sample file to the board completes successfully. Searching the resources that TI has online, I found this, but there is no response:
http://e2e.ti.com/support/power_management/battery_management/w/design_notes/using-bqeazy-to-write-configuration-data-to-bq27501-causes-amp-quot-run-time-error-6.aspx
Has anyone seen this issue, and if so, how do I resolve this problem? Thanks very much.
