Hello TPS25200 gurus!
Can the TPS25200 be used in the attached PDF drawing? And if not - what would you recommend. The load current is low, <100mA, but we need to protect both the power rails feeding the Piezo Bridge from short circuits (the load cell is at the end of a cable that could be damaged).
TPS25200 in a Negative supply 3'18.pdf
Thanks!
