Other Parts Discussed in Thread: BQ76PL455A
I have a question regarding one specific error I keep having. I managed to make my two bq76PL455A ‘s work properly, that is I can give them addresses, assert GPIO pins, read voltages, etc. However the FAULT_N pin will never go high indicating a fault condition. Upon reading the fault registers the devices suggest a “USER_CKSUM_ERR” in the Chip Fault register. For the CRC-bytes I send form the host microcontroller I even used the CRC-generator web tool that was recommended by the Softwareguide for the devices and switched the order of the two CRC bytes like it was described in that document. I double and triple checked every sent message and the CRC bytes should be correct, but I keep having the same fault. Ignoring the FAULT_N pin is no option, since I plan to use it as a hardware safety feature.
Can someone please tell me what I am overlooking or doing wrong?
Thank you in advance !
Danyal Yitik
