I am using BQ27421-G1 with panasonic NCR18500A 2040mah battery. Spec of BQ27421-G1 mentiones about 4 design parameters that need to be configured in order to achieve accurate gauging of the target battery.
Out of which one is taper rate. According to spec,Taper Rate = Design Capacity / (0.1 * Taper Current).
I couldnt find the taper current value anywhere in BQ27421-G1 and NCR18500A datasheet. Can anyone help me to configure taper rate ?
Thanks.
