WEBENCH® Tools/BQ34Z100-G1: regarding updating values to ic through bqstudio for learning cycle
Part Number: BQ34Z100-G1
Other Parts Discussed in Thread: BQSTUDIO,
Hello Everyone,
iam testing battery of model : lead acid , 12v voltage , 1.3Ah capacity.
i am able to get voltage in bqstudio.
i updated design capacity :1300 mah and design energy :15600  , qmax :1300 , chemistry id to :0802.
please guide or give me any another values to be updated to ic through bqstudio.
  • Hi Manoj,
    We've seen this question too and will answer it.
    David
  • Hi Manoj,
    Please be sure you use the Chemistry plugin in bqStudio to update the chemID (battery profile). Simply changing the number in dataflash does not change the profile.
    For other parameters, the best starting point is to follow the step-by-step design procedure in the bq34z100-G1 datasheet. One exception is the Flash Update OK Cell Volt. For lead-acid and NiMh a value of 1V is typically okay so ignore the formula in the datasheet.
