How do you add a LDO to the output of the adjustable version of the LM2596 and still be able to get a adjustable output for the overall circuit adjustable via a potentiometer or something like that?
Hi Andy,
I'm not sure if I've understood your question; but I guess what you want is to add a LDO to the output of the buck converter for better DC output; and you also want to use a potentiometer to get both converter and LDO output change with same dropout voltage, right?
Please let's know more details about your application, so, we may give you better solution.
Thanks!
Phil
Hi Andy,
From what you said, I think it's about overall system design for bench-top power supply; it's a little beyond of part application support.
Please let's know if you have questions about the device itself.
Thanks!
Phil
