Other Parts Discussed in Thread: BQ78350, BQSTUDIO, EV2400,
Hi T.I.,
I've been trying to find solid information on equipment setup and steps in order to compile a GPC package to upload chemistry and CEDV gauge constants, but I can't seem to find any concrete methodology to do it. I've been taking info from here and there, but a comprehensive list of necessary or suggested equipment and a list of steps would be helpful. We are currently using the bq78350, with the EV2400, and bqstudio 1.3.80 for an 11000maH, 6S, 22.2V lipo pack [LiCoO2 cell chemistry (unknown manufacturer)].
1) I've seen that you will need 6 data log files + a config file, zipped and uploaded in order to configure the CEDV coeffs.
i) What should be the equipment setup to ensure we get accurate data?
ii) What's the step by step procedure for acquiring the data. Can I use the steps in "Simple Guide to CEDV Data Collection for Gauging Parameter Calculator (GPC)"?
2) I read that you need to do a relax-discharge-relax log to get a new Chem ID.
i) Should I use the same equipment setup as with the CEDV coeffs to do this log?
ii) Is the 2-hour relax- C/10 discharge to Vterm - 5-hour relax the valid procedure?
iii) Is this going to help accuracy seeing that I have the above info about the battery/ cell?... should I do this to increase accuracy?
JP
