About setting slave address
Part Number: LP8860-Q1
Please tell me about LP 8860-Q1.
When using two or more ICs, is it possible to set the slave address when controlling with I2C?
Thank you.
  • Hi Tanemura-san,
    LP8860 doesn't support various slave address using I2C to drive multiple ICs. If all ICs need to be controlled for same register, all ICs can be accessed with same slave address. If SPI I/F is used, individual chip select signal can enable this separate access for each ICs.
    Hope this helps,
