TPS27S100: Why serial resisters between MCU and TPS27S100 are recommended?
Part Number: TPS27S100
Hi team,
Though, the datasheet says that the resisters will protect MCU, I would like to understand more deeply this.
What kinds of noises do these resisters protect MCU from? and so on..
Noriyuki Takahashi
    The resistors protect the MCU in case of abnormal situation such as reverse polarity. The TPS27S100 I/O pins have ESD diode from the pin to GND. In case of reverse polarity, the current flow from GND, through the ESD diode and MCU. These resistors limits the current a prevent damage of the TPS27S100 and the MCU as well.
