BQ76PL455A-Q1: drive external mosfet with pwm signal
Part Number: BQ76PL455A-Q1
Hi ,
Can i use the BQ76PL455A-Q1 or BQ76PL536A8Q1 to drive my external mosfet with pin EQ1..EQ16 with a PWM signal ?
i'm planning to use around 100khz frequency for driving mosfets.
  • Karim,
    the bq76PL455'a EQ pin are  not designed as PWM Predriver, rather as DO. The output response time is constrained to how fast the user wants to TURN ON/OFF the  Cell Balancing(CB). Typically these are very low speeds.
    hope this helps out.
