TRM says “Once updated, the bq34110 device writes the new FullChargeCapacity() value to data flash to Learned Full Charge Capacity”
- If we erase and reprogram dataflash should we assume that this value will be gone and we’ll have to do it again?
- Can we fix that by reading the value out of dataflash and putting it into the dataflash image we program in using bootrom mode?
- TRM says: “The bq34110 device updates FCC after the battery undergoes a qualified discharge from nearly full to a low battery level”
- How low of a battery level does it expect?
