TPS53679: Manual or User's guide for Fusion Digital Power Designer
Guru 11170 points
Part Number: TPS53679
Hi all,
I have a requeast.
I looking for Manual or User's guide for Fusion Digital Power Designer. If you have it or their, please let me know how to obtain.
And question.
TXT file exported from Fusion Digital Power Designer, is it able import to GUI?
ACGUY
  • Hi ACGUY,
    Yes, the text file of register settings can be read back into the GUI at another time. In the Configuration window for the TPS53679 click File -> Import to Device and you'll be able to select the text file in the new window that pops up.
    For a User Guide you can find one in the main GUI window that gives the overview of all the rails on the bus. Click Help ->  Document_Help_Center at the top of the window.
    From there you can then download an overview to the Fusion GUI as a whole as well as a specific tutorial for VR13 Regulators like the TPS53679.
    Please let me know if you need anything else.
    Cheers,
    Carmen
  • Hi Carmen,
    Thank you for answer. About import file I tried it. However, I could not select TXT file. In the pull down list, there is tifsp file only.
    Please let me know the procedure for TXT file select.
    ACGUY
