Compiler: BQ27541-G1 Behavior in low temperature
Other Parts Discussed in Thread: BQEVSW, BQSTUDIO
hey onyx
first
1-i dont knowhow to save .dfi file before updating
2-with rom mode i have no communication (no acknowledge..)so i couldnt continue some steps due to that
3-read the DFI under the updated firmware version ,what does it mean?
thank you
i joined a file of what am doing
An abstract.pdf
  • Hi Milla,
    Here is what you should do.
    -Program the gauge as you described using the senc firwmare contained in the link below
    www.ti.com/.../sluc368
    -After programming, make sure to hit the execute button.
    - Then you can open bqstudio as that will allow you communicate with the device and do your configurations instead of using bqevsw.
    I hope this helps.
    thanks
    Onyx
