TPS40210: TPS40210 Design for Positive and negative output issue
Part Number: TPS40210
Other Parts Discussed in Thread: TPS55340
Hi,I want to use TPS40210 design as (Vin=12V, Vout1=12V/0.2A,Vout1=-12V/0.2A) Positive and negative output ,from the dataheet can be known TPS40210 with flyback ,could you help check whether TPS40210 can be done it,if can,could you help to give me Classical application circuit?tks!
