Part Number: TPS2492
Voltage output at Pin IMON = 48 x (Voltage at Pin VCC - Voltage at Pin SENSE)
From VCC & SENSE input to IMON output, what is the frequency bandwidth? This is not mentioned in the datasheet.
If the current changes at 10 KHz, e.g. to drive an BLDC, will the IMON output still mirror the current waveform well?
Thanks.
