BQ24078: BQ24078
Guru 13485 points
Part Number: BQ24078
I have a problem with BQ24078. When battery is fully discharged, BQ24078 turned itself off and even if battery is disconnected, there is no current supply to the system load. After I didconnect load several times under input voltage BQ24078 begins to work as usual and to charge battery and to provide current to the system load.
power management.pdf
