Could you tell me about TPS2085 turn-on/turn-off time.
The dominant parameter of the turn-on/turn-off speed is the load capacity.
Is this correct in your understanding?
Do "voltage and current condition” influence turn-on/off speed in ”ms” order?
Yusuke/Japan Disty
Hi Yusuke,
If you take a look at figures 12 through 15, you can actually see how the input voltage has an effect on the timing parameters for the device. In general, the higher the output load and capacitance, the longer the turn on may take. However, the specs in the datasheet are maximum numbers that are expected across process and temperature.
Alek Kaknevicius
