Other Parts Discussed in Thread: BQEVSW, BQ27541-V200, BQSTUDIO
hey all
after finishing the learning cycle,i realised that the learning cycle is 36 instead of 0!
what should i do ?
thank you
hey all
what should i do ?
thank you
Milla,
I'm not clear on what you did, but after a successful learning cycle update status should be 0x06. See page 25 of the datasheet.
Also here's an app note on achieving a successful learning cycle.
thanx for your answer
the update status is on 06 yes ,but i have realised that the cycle count is 36 instead of 0!
what should i do ?
hey
thanx
yes ,am creating a golden image,but how can i st the cycle count to 0?
thank you
Use bqEVSW to connect to gauge then select "Data Flash" then select "Gas Gauging" tab. "Cycle Count" is in the far right table. Click "Read All" to read and display current gauge data flash setting. Change "Cycle Count" to 0 then hit "Enter" key on your keyboard. Click "Write All" to ensure all values are written to Flash memory.
