Question about LCD bias IC
Other Parts Discussed in Thread: TPS65132
I am looking for the LCD bias IC.
VCC=3.3V
I2C(3.3V)
Vout=±5V
I found TPS65132.
Do you know the best IC other than TPS65132.
Please also check the attached document.
Takahiro NishizawaLCD bias.pptx
    TPS65132 is what we call a "Split-Rail Converter" (Generates positive and negative output voltage). the Missing data point in your description is: which current the device needs to be able to provide. You can find the parametric search for all our split-rail products here (click). Select the device based on your current requirements.
    Christian
