TPS55340: doesn't boost after activating ENABLE pin
Part Number: TPS55340
Hi Helen:
  I have more questions:
-      I couldn’t find the solder curve of this IC, Could you send me this curve?
-      I attached a datasheet of the solder past that we use for solding this component, Could you verify if it is good enough of not?
Thanks for your help.C5000009 SN SMD PB CARACTERISTICAS.PDF
Best regards
