Dear All:
when I use the BQ24780S, If system power demand is temporarily exceeds adapter rating, the bq24780s supports hybrid power boost mode to allow battery discharge
energy to supplement system power, officially the input current is limited, but I find sometimes the adapter current exceed the input current limit value in turbo boost mode
you will see the phenomenon in my product application, that the turbo boost mode and Underclocking happened at the same time.
can you explain the issue? thanks!
