BQ34110: Logging error with Battery Management Studio
Part Number: BQ34110
I have an issue with the data logging on battery management studio.
I'm using the BQ34110 EVM and an EV2300 (with firmware 3.1c). The EVM is connected to the EV2300 with the cable given with the EV2300.
When I try to log the data for the learning cycle, I have a lot of error in the log file.
I attached the log and err files to this message.
What should I do to avoid this errors ?
Thanks for your help !
Mickael
logfile.txt
Tue Jun 05 14:22:22 CEST 2018
Time,LogCaption,Error Code,Error String
2018-06-05 14:22:22,CycleCnt,772,No acknowledge from device.
2018-06-05 14:22:54,Voltage,772,No acknowledge from device.
2018-06-05 14:23:18,CycleCnt,772,No acknowledge from device.
2018-06-05 14:23:30,AvgTimeFull,772,No acknowledge from device.
2018-06-05 14:24:14,Batt Stat,772,No acknowledge from device.
2018-06-05 14:24:26,AvgTimeFull,772,No acknowledge from device.
2018-06-05 14:24:50,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:25:34,Batt Stat,772,No acknowledge from device.
2018-06-05 14:25:46,AvgTimeFull,772,No acknowledge from device.
2018-06-05 14:26:10,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:27:14,SmRemCap,772,No acknowledge from device.
2018-06-05 14:27:14,SmCurrent,772,No acknowledge from device.
2018-06-05 14:28:10,SmRemCap,772,No acknowledge from device.
2018-06-05 14:28:10,SmCurrent,772,No acknowledge from device.
2018-06-05 14:28:34,CycleCnt,772,No acknowledge from device.
2018-06-05 14:29:06,Voltage,772,No acknowledge from device.
2018-06-05 14:29:58,Voltage,772,No acknowledge from device.
2018-06-05 14:30:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:30:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:30:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:30:58,Voltage,772,No acknowledge from device.
2018-06-05 14:31:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:31:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:31:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:31:58,Voltage,772,No acknowledge from device.
2018-06-05 14:32:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:32:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:32:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:32:58,Voltage,772,No acknowledge from device.
2018-06-05 14:33:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:33:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:33:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:33:58,Voltage,772,No acknowledge from device.
2018-06-05 14:34:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:34:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:34:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:34:58,Voltage,772,No acknowledge from device.
2018-06-05 14:35:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:35:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:35:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:35:58,Voltage,772,No acknowledge from device.
2018-06-05 14:36:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:36:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:36:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:36:58,Voltage,772,No acknowledge from device.
2018-06-05 14:37:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:37:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:37:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:37:58,Voltage,772,No acknowledge from device.
2018-06-05 14:38:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:38:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:38:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:38:58,Voltage,772,No acknowledge from device.
2018-06-05 14:39:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:39:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:39:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:39:58,Voltage,772,No acknowledge from device.
2018-06-05 14:40:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:40:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:40:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:40:58,Voltage,772,No acknowledge from device.
2018-06-05 14:41:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:41:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:41:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:41:58,Voltage,772,No acknowledge from device.
2018-06-05 14:42:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:42:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:42:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:42:58,Voltage,772,No acknowledge from device.
2018-06-05 14:43:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:43:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:43:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:43:58,Voltage,772,No acknowledge from device.
2018-06-05 14:44:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:44:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:44:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:44:58,Voltage,772,No acknowledge from device.
2018-06-05 14:45:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:45:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:45:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:45:58,Voltage,772,No acknowledge from device.
2018-06-05 14:46:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:46:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:46:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:47:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:47:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:47:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:48:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:48:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:48:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:49:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:49:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:49:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:50:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:50:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:50:06,ChgCurr,772,No acknowledge from device.
2018-06-05 14:50:58,Voltage,772,No acknowledge from device.
2018-06-05 14:51:02,AccumulatedCharge,772,No acknowledge from device.
2018-06-05 14:51:06,AvgCurr,772,No acknowledge from device.
2018-06-05 14:51:06,ChgCurr,772,No acknowledge from device.
