Hello guys,
One of our customer is designing a evaluation circuit for TPS61193.
They'd like to know how to calculate CFB placed between LED anode (output voltage) and FB terminal as typical application, Figure 20 on page 20 in TPS61193 datasheet (SNVSAF4B).
The datasheet says "In boost mode a 15-pF capacitor CFB must be placed across resistor R1 when operating in 300-kHz to 500-kHz range (see Typical Application for 3 LED Strings).
When operating in the 1.8-MHz to 2.2-MHz range CFB = 4.7 pF." on page 12. But it doesn't say about CFB in 500kHz~1.8MHz switching frequency case.
If customer uses 500kHz~1.8MHz switching frequency, how can CFB be calculated?
Could you please tell me how to calculate CFB in the switching frequency range?
Your reply would be much appreciated.
Kazuya Nakai.
