Hello dear Ti community.
I was using LM317 for a quite long time in my cheaper circuits.
But then I was wondering about something better and LM317 was leaved behind due to TPS7A regulators and some other stuff from Linear Tech.
But after all there is much more to do with LM317 to improve it performance in term of PSRR, noise or output impedance.
A I've go some question related with those mostly.
1) how about CADJ? Should it be special kind? I mean tantalum (solid, polymer) electrolytic (ESR range?) or classic ceramic (X7R), or maybe something else?
There is a plenty of non popular capacitor called as a film, builded around plastic or acrylic that could be used there.
Even big film capacitors (there is a possibility to buy 10uF film cap with 5mm raster).
I know this is kinda old regulator, and datasheet is mostly copy-paste of old paperwork from that time.
2) how about replacing R2 with a zener diode or even shunt regulator (TL431 for that matter) it should improve noise performance, because dynamic impedance of a zener or shunt regulator is MUCH lower than a R2 itself.
Or maybe there is a better way to improve this aspect of performance? How about TL431 will it work well, or maybe is should pick something else?
3) how about lowering output impedance to avoid any resonance that might be pronounced by a capator itself?
LM317 output impedance is kinda high and it will rise quickly just before 1Khz.
In reagard to this document, method described there should help me with this aspect, but what do you think?
Another important thing here is what of capacitors should be used for best performance?
4) question about "shutdown" option, as I remember it was descibed in a datasheet, I assume that when 0 level will be pushed out then regulator itself will output voltage equal to it's reference?
In this case it will be 1.25V ?
5 is there exist any kind of circuit that could be used between LM317 and LM337 that will be mutual shutdown circuit, that will halt regulators if one rail collapse?
I saw something like than in a Douglas Self book, but he was using both positive regulators with separate transormator windings.
Just for your reference I will post a picture that will show few things in regard to my questions.
