Hi,Buddy
I want use the TPS60400 as a voltage inverter, so the output is a negative voltage , and in the datasheet, the output current is 60mA,
Could you tell me it is a current sink or source, in other words, can I pull the output to ground through a resistor when the output used as a sink?
