Hi Team,
TRM shows the following.
(page 14)
The data flash parameter Learned Full Charge Capacity should be initialized to the Design Capacity mAh.
DOD at EDV2 should be initialized to (1 – Battery_Low%) × 16384, where Battery_Low% = Battery Low % ÷ 100.
http://www.tij.co.jp/jp/lit/ug/sluube6a/sluube6a.pdf
I understand Learned Full Charge Capacity should be initialized to the Design Capacity, however regarding "DOD at EDV2" I couldn't catch which parameter of bq27320 should be initialized.
Is it "Fixed EDV 2" in Table 3-3?
Yaita / Japan disty
