TLV733P: TLV733P load transient response verify
Part Number: TLV733P
Hello Expert
Could you share the equipment vendor and its setting for TLV733P datasheet figure 25~figure 28(Load transient test waveform).
My customer can't use their equipment to touch the goal of slew rate of current climbing.
  • Hi Alex,
    We use resistive loads to perform our load transient waveforms provided in the datasheet. We select R1 for the lower current in the transient and R2 so that R1||R2 yields the higher current in the transient. A FET is used to connect/disconnect R2 from the circuit. The gate of the FET is driven by a function generator. We have several different function generators and have found that the specific brand or model of function generator does not influence the test results.
    Very Respectfully,
    Ryan
