The datasheet calls out 40mv/us slew rate on the ON/OFF pin. What's the symptom when failing this requirement? If the ON/OFF pin ramps too slow, would it cause LDO no output or output bouncing but will eventually up? And what's the cause? Thank you.
Sandburg
